Message 11 of 13
Re: Setting Up Digital Voice
Thanks, is that just switching the router off and on again or doing a factory re-set?
Message 12 of 13
Try switching off and then on and see if that helps but if not then try factory reset
Message 13 of 13
Bingo! Switched the router off and on and that Smart Hub Manager address now shows the phone icon with "Phone" and then my landline number. Just rang it from my mobile and it connected as expected.
Thanks for your help
