Message 1 of 2
Smart Hub-2 and telephones
Hi,
We are just changes to the new telephone system. I've ordered the adapter to connect our current landline telephone to the router.
My question is; can you connect a telephone to the router as well?
The reason being is that we have a telephone we like to use that isn't compliant with the other telephone we have.
Thanks,
Steve.
Steve.
1 REPLY 1
Message 2 of 2
Re: Smart Hub-2 and telephones
@Glosgas
Yes you can, there is a socket on the back of the Smart Hub 2.
