Message 1 of 3
Smart Hub
I am using hub manager to try to export contact list from Advanced Phone Z. It just gets stuck in "Exporting" and no download file appears ??
2 REPLIES 2
Message 2 of 3
Re: Smart Hub
That's because the contact list for the Advanced Phone Z isn't stored on the hub. Only DV handset contacts are stored on the hub. There is no way to export the contact list from the Advanced Phone Z
Message 3 of 3
Re: Smart Hub
Many thanks liquorice. Not the answer I wanted to hear, but the answer I needed to hear, Looks like I'll have to use the backup method my wife recommended all along:  pencil & paper!
