Message 1 of 5
Speakerphone
I have recently bought digital voice and it seems to be lacking any speakerphone facility. Is this correct? If so it will be a nightmare given how long we all have to wait to speak to a real person. If there is one I would appreciate being told how to find it, please
4 REPLIES 4
Message 2 of 5
Re: Speakerphone
@unhappy001
With most digital handsets pressing the green button again, while on a call, activates the speaker. I am not sure that is the case with the BT supplied phones.
Message 3 of 5
Re: Speakerphone
You can always connect an analogue speakerphone via the port on the hub if not comfortable with what the BT Digital phones provide. I believe you can also sync a 3rd party Dect phone to the Hub.
Message 5 of 5
Re: Speakerphone
@Keith_Beddoe is right. I have the advanced Alexa handset and the green button has a speaker symbol (of sorts). The same symbol appears on the essential handset just above the button.
