Message 1 of 8
Trying to order digital voice adapter, says number not eligible
Got letter last week re DV move within 30 days and card saying how to order a free adapter. I need an adapter because phone and router are in different rooms.
When I go to bt.com/dvequipment it redirects to an ee page asking for the landline number to get a voucher code. When I put my full number in it says "The number entered is not eligible for this offer. Please check you have entered your number correctly."
I've tried several times over the last few days and on different browsers with the same result. Has it worked for anybody recently?
7 REPLIES 7
Message 2 of 8
Re: Trying to order digital voice adapter, says number not eligible
Message 3 of 8
you can try text  'ADAPTER' to 61998  of phone Cs 03301234150 and request one.  it may be as you are not on DV that you need to wait until you actually have a DV activation date
Message 4 of 8
You are not alone. I have tried putting my number into that site and get exactly the same result as you even though I am very definitely on digital voice.
Message 5 of 8
I gave up on the web link and texted ADAPTOR to 61998 from my wife's EE mobile, happy to say it arrived today!
Now I just have to hope a Smart Hub 2 arrives before the switchover.
Message 6 of 8
I am due to switch over soon to DV and have received "Your useful guide to Digital Voice". It reckons to text ADAPTER to 61998 rather than ADAPTOR (with and E instead of an O). Just saying...
Message 7 of 8
My notice definitely spelt adaptor with an o and the device arrived a few days after texting.
The switchover I was told would be by mid-April did not actually happen until October just after a new Smarthub was delivered. Everything went smoothly and our old Panasonic phone works fine through the adapter.
Message 8 of 8
BT is obviously flexible about this! Both spellings work because I just received a confirm that mine is on the way. Also, thanks Ivor77 for the information about Panasonic phones. I have them around the house so pleased that they will work.
