Message 1 of 7
Upgrade question
If I accept my current offer of Full Fibre 100 what happens about my landline phones, currently a set of four DECTs coming in via an overhead line?  And is there a risk of losing our present number?  Currently on fttc, no issues at all.
6 REPLIES 6
Message 2 of 7
Re: Upgrade question
If you are moved to Digital Voice, you will keep your number and you simply transfer the base station from the master socket to the green socket at the rear of the hub.
Message 3 of 7
So being transferred to DV isn't a given, might I be left on copper?
Message 4 of 7
It will happen eventually, but not entirely a given at the moment although a high probability.
Message 5 of 7
Thanks for clarifying 😎
Message 6 of 7
Message 7 of 7
Thanks for the article. I'm fine at present with both BB and phones so will sit on my hands for the time being.
