Message 1 of 13
Using Mobile Phone as a Handset with Digital Voice
Is it feasible to use mobile phones as additional handsets with the Digital Voice landline from BT and if so then are there Apps/information to help BT customers using their mobile phones as handsets?
12 REPLIES 12
Message 2 of 13
Re: Using Mobile Phone as a Handset with Digital Voice
Message 3 of 13
@kanesh
Mobile phones do not use DECT, they use either the mobile network, or Wi-Fi.
BT Digital Voice uses DECT to communicate with the BT handsets.
So the answer would be no.
Message 4 of 13
digital voice connects to SH2 base by dect not wifi so mobile will not connect to base.  you could divert all incoming calls to your mobile especially if BT mobile
Message 5 of 13
You can use call diversion completely free of charge if the mobile you are diverting to is on the BT network but of course you are limited to 1 phone
Message 6 of 13
Thank you all. I remember using the BT SmartTalk App a few years ago to make VoIP (landline) calls from mobile phones. This was when our landline wasn’t using VoIP/DV. Surely with the VoIP/DV landlines, it must be technically feasible to implement something where we can utilise our mobile phones with our landline system instead of spending money and power for separate landline phones.
Message 7 of 13
@kanesh
then why not just get Broadband without landline (still need to pay line rental) and use your mobile instead?
Message 8 of 13
Although it may be technically doable, is there the demand to warrant developing an application for it ?, chances are your mobile supports WiFi calling , so when in range of your ‘hub’ , your mobile uses your broadband and not the mobile network ( and presumably the mobile provider doesn’t charge for any usage that possibly would be chargeable, when operating in this mode ) , so what would be the point if your mobile could mimic a DECT phone and connect to the hub but use ‘DV’ ,apart from the CLI would be the ‘landline’ number , not the mobile number ?….and as said , if it’s a cost issue , BT offer a no telephony option ( so no DV , no landline number etc ) which saves a small amount per month and your mobile still can use WiFi calling.
Message 9 of 13
I understand the question as I want to do the same thing.  It’s all about keeping the landline number - which is like your home address for many people.  When someone rings that I would like my mobile to ring, as well as any other phones connected directly to the DV service.  It’s standard VoIP so why not over the Wi-Fi.  Noting to do with DECT.
Message 10 of 13
Hi @hollandpt   You could use the BT Premium Phones plugged into the Smart Hub 2 which will give you a Bluetooth connection so you can answer your calls on your mobile.
