- Mark as New
- Bookmark
- Subscribe
- Subscribe to this message's RSS Feed
- Highlight this Message
This morning at 08:56:15, I received a call from my own number, it was annotated as "Nuisance" on the handset.
Also logged in my recent callers.
This is not the first time this has happened.
Is it possible for BT to trace the origin of this call?????
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
Voicemail digi essentials phone
When a call is sent to voicemail, and the calls button is pressed on the handset, does it display my home phone number??
- Mark as New
- Bookmark
- Subscribe
Re: Voicemail digi essentials phone
Hi @5progface.
Can I just check, is it an outgoing call that you are making that is going to voicemail. or is it for an incoming call to your phone?
Michael
- Mark as New
- Bookmark
- Subscribe
G'day Michael
These are incoming calls, which go to voicemail.
When I press the calls button on the handset, the display shows my home phone number.
- Mark as New
- Bookmark
- Subscribe
Also received a call at 0909 this morning and display shows my Home phone number
- Mark as New
- Bookmark
- Subscribe
It is logged in my recent callers
- Mark as New
- Bookmark
- Subscribe
Checked my Voice mail on phone and two calls at 0909 were from 07378905507 from Parcelforce.
But when I pressed calls on the phone one showed up as my home phone number.
Another incoming call at 0909 on phone display showed my Home phone number.
- Mark as New
- Bookmark
- Subscribe
It can often be the case that with some spam calls , they spoof the number they are calling from and use the same number they have called , so if you answered the call ‘live’ and looked at the display on the phone as it were ‘ringing’ , the number displayed is your own number , and should you use 1471 ( last number that called you ) it reports your own number , because that’s what the scammer programmed their system to forward as the CLI information ( calling line information ) …why they do this is unclear , obviously if the CLI said International or something you probably would never pick up the phone .
- Mark as New
- Bookmark
- Subscribe
A live call on the phone display showed my home number, but it was from Parcelforce.
- Mark as New
- Bookmark
- Subscribe
Has it only been calls from Parcelforce that you have noticed it happening on or has it been other numbers as well, @5progface?
Michael
