Message 20 of 39
Re: Voicemail digi essentials phone
Call this afternoon went to voicemail.
On the handset, I pressed the calls button and Yes, my own number was displayed.
Checked my calls log on the website and my own number was logged as an incoming call.
Message 21 of 39
Thanks for confirming that @5progface.
When you actually call 1571 to listen to your voicemail, does this give the actual number that called?
Also if possible, have you had the chance to try connecting a different phone to see if the same issue occurs with this?
Peter
Message 22 of 39
When I listened to the actual voicemail the number of the caller was read out as part of the message.
I do not have another phone to try.
It is probably the way that voicemail has been programmed.
Why not ask Techs at BT to call each other and see what happens.
Or ask them how the system is programmed.
Message 23 of 39
@5progface I have Digital Voice myself and gave this a test, and it's not something I encountered.
When leaving voicemail, the missed call history was always showing the number of the caller.
If you get back in touch with our team they'll be able to check on how everything is configured at our end, but we can't rule out it being linked with the handset too.
Peter
Message 24 of 39
This what I think is the sequence of events with voicemail.
Incoming call goes to voicemail.
System forwards call to recipients number. Which is then logged in recipients incoming calls log as their own number
Callers number is read out as part of voicemail message.
Message 25 of 39
I'll wait until another call is sent to voicemail and check this again
Thanks for your reply
Message 26 of 39
Received a call from a family member this afternoon.
The correct telephone number was shown on bt handset and in my online calls log.
I am now waiting for the next call to be forwarded to voicemail and check again.
Message 28 of 39
Re: Spoofing my telephone number
No , it not traced , arguably its traceable, but that a pointless endeavour, the IP address may be logged , but it’s a spam call , hence BT indicating it as a probable nuisance call …..BT do intercept huge quantities of these calls and continually act against them , but these scammers are not stupid people , and often operate in places where law enforcement don’t regard this as a serious matter, enabling the scammers to operate pretty much unhindered.
Message 29 of 39
Thanks for the swift reply.
On investigation, I found that the call was actually from Parcelforce.
The call went to voice mail and was logged at 0855 according to the voicemail message.
So I wonder how it is that the handset shows my number and is annotated as nuisance?
Same thing happened last time I was expecting a Parcelforce delivery.
Message 30 of 39
I am rather concerned about this situation, if my handset is showing my own telephone number as Nuisance, if I now make a call, will it show on the recipients handset as Nuisance ???
If so, will BT remove my number from the Nuisance list?
