Message 1 of 3
Vulnarability list
We have had our Landline off (no dialling tone) for the past week, this is a regular thing, we are both in our 80's with  medical needs, we have no mobile reception, and no public transport. Is there a list we can be put on for breakdowns?       Also where can I find list of times and dates we have been without service? Thanks Peter.
Tags (1)
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: Vulnarability list
https://www.bt.com/help/landline/getting-set-up/help-people-with-impairments-or-with-particular-need...
Not aware of any logs of outages unless you've reported faults each time, in which case you should be able to see faults here.
Message 3 of 3
Hi, in the interim before you get added to any list can I suggest you get back on to BT (assuming they are your provider) and ask if they would raise your case as an emergency welfare.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
