Message 1 of 4
What is the process of getting a BBU, and what does it do?
After reading an article recently it said that if you're a vulnerable customer you can request a BBU for the ONT, for in case of a power cut.
Does the BBU only power the ONT? Can it also power the router too?
I'm thinking its only powering the ONT. But in case of a power cut, with the phone plugged in to the router, how is this allowing me to make a phone call during a power cut?
Or am I wrong about the purpose of the BBU?
3 REPLIES 3
Message 2 of 4
Re: What is the process of getting a BBU, and what does it do?
do you have a good mobile phone signal/service?
Message 3 of 4
Yes,
I was just wondering how the BBU worked.
Message 4 of 4
It just powers the ONT. You either need a separate one for the hub or a UPS to power both.
