Message 1 of 10
Where is BT's Nuisance Call barring feature
Where is BT's user controlled spam caller blocking list for landlines?  I've used it before to bar spam callers, and although am finding reference to it on BT.com, cannot actually get in to it, to add one, despite having used it before and finding oblique references to the service.  A simple link would be great.
9 REPLIES 9
Anonymous
Not applicable
Message 2 of 10
Re: Where is BT's Nuisance Call barring feature
under land line
in if you ckick landline in your products page its on there
right at the bottom of this page
"get more from my bt"
https://my.bt.com/s/apps/appsmybt/#/home
"your products"  manage then "landline "
Message 3 of 10
You'll be wasting your time though. Blacklisting an infinite amount of numbers is a futile exercise.
Whitelisting with a call blocking phone is the only viable option.
Anonymous
Not applicable
Message 4 of 10
@licquorice not really i hust block everything that i dont know
if you move to digital boice then one of  these Digital Home Phone
https://www.bt.com/broadband/digital-voice
Message 5 of 10
But the scammers spoof the numbers, they never use the same number each time. What's the point in blocking a number they won't use again.
Anonymous
Not applicable
Message 6 of 10
all he want is advice and that what i give him
@licquorice
Message 7 of 10
Indeed, as did I.
Message 8 of 10
Sorry but that isn't helping.
Where is the BT Call Protect page I can log into and see/add numbers?  All references to this just lead round and around without getting to the detail I need.
Message 9 of 10
Go to MyBT> My products > Digital Voice> Call protect
Call protect is only of use to block 'genuine' numbers that you don't wish to receive calls from. Scammers spoof a different number every time.
Message 10 of 10
Thanks! Got it.
