Message 1 of 10
BT Digital Voice Handset
My BT supplied handset was working  but since migrating to EE it has stopped and just says to connect to hub by pushing WPS button. This it fails to do. Any suggestions
9 REPLIES 9
Message 2 of 10
Re: BT Digital Voice Handset
are you using a different hub now with EE?  if so you need to unpair the phone from the old BT hub and then re-pair with new EE router
Message 3 of 10
@imjolly thanks for that quick reply. I had read somewhere else that was what was required  but how to do it as handset is stuck on 'register handset to hub' which I am unable to perform.
Message 4 of 10
@imjolly sorry yes forgot to say phone was paired to BT hub but now with EE
Message 5 of 10
Do you still have the BT hub and if so just connect it to power no need for internet and see if phone will re-connect back to BT hub.  If so then un-pair from BT and then pair with EE
Message 6 of 10
@imjolly sorry no can do hub returned to BT some while back
Message 7 of 10
Can you try
Resetting a BT Digital Voice Handset
Press the left option button: on the phone to bring up the phone's menu.
Use the navigation buttons: to scroll to and select Settings.
Scroll down: to the Reset option and press Select.
Select the option to Reset handset: or similar, which will perform a factory reset on the handset.
Message 8 of 10
@imjolly thanks for all those responses but I had already tried them and handset screen just keeps taking me back to 'register handset to hub'. Had previously tried unplugging from mains  leaving off charge. Would take out battery  but cannot find way into casing.  I'm  all out of ideas.
Message 9 of 10
try this previous post   https://community.bt.com/t5/Home-phone-including-Digital/How-to-replace-batteries-in-a-BT-Advnced-Di...
Message 10 of 10
@imjolly thanks for that information.  I don't know what I hope to achieve.  I'm  thinking I may be able to do a factory reset. We shall see.
