Message 1 of 4
digital phone suddenly stopped showing seller's name
my digital phone has suddenly stopped showing names of callers even though they are in my contact list.
3 REPLIES 3
Message 2 of 4
Re: digital phone suddenly stopped showing seller's name
@Kathleen30
Are you a BT customer, if so, which phone are you using?
If you have been moved to BT Digital Voice, then caller display need to be enabled on your BT Digital Voice options.
Message 3 of 4
I have an Essential Digital Home Phone (BT). It says in manual 'if the caller is in your Contacts, your screen will turn green and their name will be displayed.' This was happening but has suddenly stopped.
Where can I find Digital Voice Options?
Message 4 of 4
