Message 1 of 5
digital switchover
My elderly mother has been told that her line switched over last Thursday.   Given that she:
A) doesn't have broadband and
B) Never saw a BT engineer as its done offsite
How can we prove it's been done? Will she get a letter from BT?
4 REPLIES 4
Message 2 of 5
Re: digital switchover
Has your Mother's phone line (plugged into the wall socket) gone dead? If not, then the switchover hasn't taken place.
When you say "your mother has been told" - who did this? Was it a message from BT? In which case it presumably was by letter - but you say you're still waiting for a letter?
People without broadband service will be the last to be switched to DV - and, AFAIK, BT has not yet finalised how it's going to do this, so it's rather unlikely that your mother has been switched.
Message 3 of 5
Is the ‘line’ still working ? .
There is a method to convert telephone only ‘lines’ onto a different type of transitional phone service, in effect like Digital Voice , that doesn’t need a visit to the customers property , the work required is in the exchange not the customer address , as far as telling if it’s been done or not may be tricky as in effect nothing changes (that was the entire point to be as unnoticeable as possible) nothing but a small downtime while moved from one system to another , but if this small changeover time isn’t noticed , you may never actually realise you are now connected to different equipment.
If you were in an area where you didn’t have to dial  the full number on outgoing calls , so (for arguments sake ) your area code is 01999 and your number is 123456 , and you call a near neighbour also 01999,987654 if you previously could just call 987654 without needing to put the 01999 in front , you would  need to now call the full number (no short codes after changeover )  , but some areas have had to use the full national number this for years , so even that may not indicate that a change has been made , if that’s what you did anyway .
If the line is still working , does it matter if it’s still on the old network or the new network ?
You ask if she will get a letter from BT , how was she advised about the supposed change last Thursday, wasn’t that via a letter ?
Message 4 of 5
"There is a method to convert telephone only ‘lines’ onto a different type of transitional phone service, in effect like Digital Voice.."
Is this method now actually in use by BT? I thought that it was merely a proposal for people who wanted telephone but no broadband and that no decision had yet been taken to implement it. The other option I thought was still being considered was to supply such people with some sort of cutdown router to use in their houses.
Please correct me if I'm wrong about this.
Message 5 of 5
https://community.bt.com/t5/Home-phone-including-Digital/BT-s-Home-Phone-Standard-product/td-p/24493...
see links in this post if required regarding a pre digital phone line , it seems this  ‘no powered equipment needed at home’ transitional  product is now available to order ,  but isn’t the primary solution for  ‘difficult’ telephone only customers,( difficult in the sense of their situation rather than their attitude) it’s not preferable to an all IP solution , namely BTDV , achieved in effect by offering a ‘free’  broadband service with DV service the only paid for product,  is the first choice solution for existing phone only customers and new customers requiring only a phone service, but there will be edge cases where this isn’t possible so this transition product is also available.
