Message 21 of 32
Re: digital voice constant emails apponment
@Anonymous Can you please double check if you have private messages enabled in your Community profile settings under preferences>private messenger as I am having an issue with sending you a private message.
Alex
Message 22 of 32
A battery back up unit (BBS) also known as a UPS (uninterruptible power supply) is the device that keeps your router (and therefore your telephone service) active during a power outage…its relatively unimportant what manufacturer is supplying it or what it looks like , search BBS /UPS for images if necessary, but basically your router connects to the BBU , the BBU connects to the mains , should the mains fail , the battery within the BBU takes over running the router until the mains is restored or the battery goes flat .
Presumably you have been identified as vulnerable if you have been supplied with extra equipment and an engineer visit arranged to help you convert to DV , something that the overwhelming majority do without any assistance, as its for most as simple as moving the phone cord from the wall socket to the router socket …….do you need this extra help ?, why do BT think you do if this visit isn’t (in your view ) necessary ?
Anonymous
Not applicable
Message 23 of 32
@Alex_H done enabled
Anonymous
Not applicable
Message 24 of 32
@iniltous if this is just case of setting this up i so not live on my own we have set many devices up
if by want to send  this extra equipmrnt if needed they can do but we can set this up if a video is provided
im assuming it this
https://youtu.be/zYmlWR6NU-g
or instructions
im aware that bt are doing the best to insure that everything goes right and I am glad of this but this has been dragging on gor months and chat with customer services yhe other say wsd the first time i have had a clear as to why
Message 25 of 32
Hey there @Anonymous 😊
Alex isn't working today, but I've picked this up from him and popped you over a private message now!
Peter
Message 26 of 32
Made one myself using a little 12volt AA battery pack. Works perfectly!
Anonymous
Not applicable
Message 27 of 32
info sent  via pm to @Peter_W thank you
Anonymous
Not applicable
Message 28 of 32
thank you this is now resolved thank you @Peter_W due to go live next tursday
Message 29 of 32
I'm really glad to hear that's now sorted for you, @Anonymous 😊
Thanks for taking the time to come back and let us know, too!
Enjoy your weekend,
Peter
Anonymous
Not applicable
Message 30 of 32
what a mess turns out BT mucked my order up and didint go live on the 20th
because the pulled both the fibre cables and the old copper cables acording to the person that rang me
have to have a tempoary phone number untill they get my line restored due to go live on 25 currently have no internet an are rely on a 4g mobile
lucky for me i have a mobile
all this because a forced move to digital voice
