Message 31 of 32
Re: digital voice constant emails apponment
But in your 8 Oct posting you said that FTTP was not going to be available in your area until next year.
So I'm confused that Openreach is apparently "pulling both fibre cables and old copper cables".
If by this you mean Openreach have disconnected both your copper cable (from FTTC) and the fibre cable that was not due to be installed until next year, I'm rather confused!!
Perhaps you could clarify?
Anonymous
Not applicable
Message 32 of 32
all i know is the pulled both cables i have no brandband
we have a part fibre connected and must of assumed we where goinf to full fibre im assuming or either they are doing doing pre work for full fibre at the echange
bt have admitted it was their fault
im just keeping peoplec aware if people are board of this then ill stop posting
thus was
