Message 1 of 4
landline phone
ive got a problem charging my bt stratus phone
just wanted to know if it would be possible to change to another bt phone but using the same cables as i have at the moment?
3 REPLIES 3
Message 2 of 4
Re: landline phone
You can use any phone you like.
Message 3 of 4
Re: landline phone
 i bought a new phone and it says you must use the cables provided it wasn't a bt phone
just wanted to know if the plugs and sockets on all bt cordless phone were the same so i could just replace old for new but using the same cables
Anonymous
Not applicable
Message 4 of 4
Re: landline phone
Plugs & sockets are the same but the wiring between them might not be. That's why you're advised to use the cable that came with the new phone.
But it will either work or it won't, so just try it. BT phones gernerally display Line Cord Error if the cable is unplugged, faulty or incorrect. If it doesn't work you need to use the new cable.
