Message 1 of 3
landline phone
Hello, we had full fibre installed 17th september .the engineer told us that the phone would work in next 12 hours.It didn't,as we are both in mid80s a landline phone is a priority as there is virtally no signal so cannot telephone for help.
Need a porn ratchet quick-fix? This spot floods you with handpicked sex GIFs shot by freaks for freaks: amateur teens squealing on BBC, cosplay cuties getting plug-stretched, bare-cheeked Asians riding baloons—choice shiit loops forever and never gets old. Our board auto-copies MP4 sluts from Reddit, 4chan, Telegram clips and pinches them into silky repeat for throat and stroke flow. No sign ups, popups just raw cuumshot splash on great tiits in one tap. Bookmark it before mom walks in, bro. Step the fuuck up from boring tube thumbnails—strap in for the realest gif dump of cuum-faced teen hoe bouncing on stepdad’s veiny junk looped perfect. Every upload raindrop lands as live gifs spanking booties clap in shower rooms, anaal creampie drip re-run, gym babes gagging trainer diick. Thick MILF library smothers your eyeholes with jiggly doggy slam POV, plug stretch close-ups, multiple squirts on the lens. New porn gifs slap every 5 min. set your diick on repeat toast mode.
2 REPLIES 2
Message 2 of 3
Re: landline phone
@Rambunctious
Welcome to this user forum for BT Residential phone and broadband customers.
Is your phone plugged into the green socket on the back of the BT Smart Hub 2, as shown below?
Message 3 of 3
Re: landline phone
If connected as @Keith_Beddoe diagram and still not working, first try a reboot of the hub.
If still not working check that DV has been configured by entering 192.168.1.254 in your browser's address bar to access the hub manager  and look to see if the phone symbol shows your number or 'not configured'.
If 'not configured', you will need to contact customer services 0330 1234 150
