Message 1 of 9
query on ringtones/voice volume adjustment: digital voice
Hi all
I've just moved house and have a new broadband/phone setup with BT SH2 and 2 advanced digital voice handsets. I've set one handset up, and am trying to figure out how to adjust the speech volume, which is a bit quiet for my ageing ear! Is this possible? Also, is there a choice of ringtones, and if so, where?
Thanks in advance
Heather
8 REPLIES 8
Message 2 of 9
Re: query on ringtones/voice volume adjustment: digital voice
Message 3 of 9
You need to go to setting on the DV handset scroll through the options and you can make the changes you need
Message 4 of 9
Thanks - I did finally find the ringtone options! I still haven't managed to find a volume control though - just 'standard' and 'treble' etc under the settings. Maybe looking in the wrong place?
Message 5 of 9
Hello.
See page 16 of the manual here which should answer your question:
BT-Advanced-Digital-Home-Phone-User-Guide.pdf
RIC9380
Message 6 of 9
That link goes to the options the OP has already located. I can't find any option to adjust the caller's voice volume and conclude that there isn't one.
Message 7 of 9
It says:
Changing the call volume
When you’re on a call, use the Vol.+
and Vol.- buttons to adjust the volume
in the earpiece, or speaker if using
hands-free.
Amplify
If you need an extra volume boost,
keep pressing the Vol. + button until
Amplify appears. Amplify will switch
off again once you’ve finished.
Works for me 😀
RIC9380
Message 8 of 9
Thanks for all your help. I finally found the volume adjust control. It was very difficult for an older person to see, hence my silly question! I caught it by peering for ages at the handset and finally found it on the central dial! Simples ... Doh!
Message 9 of 9
No worries, hjr. It baffled me for ages too. Glad you got there.
RIC9380
