Message 1 of 3
2 fibre connections different ping
Myself and my neighbour have the same bt full fibre package with the exact same set up. Running a speed test they get 5ms but when I run a speed test on my network I get 30ms.
we have disconnected all devices to ensure its a fair test. Considering we are the only 2 people connected to full fibre on our pole, and we have the same package and provider, why is my ping 30ms and my neighbour is much lower at 5ms?
2 REPLIES 2
Message 2 of 3
Re: 2 fibre connections different ping
Any one of a number of reasons.  To assume your ping will be the same as you neighbour’s is a bit like assuming traffic conditions will be the same for both of you when you drive into town.  Even on the same road, a few minutes apart, it won’t be, of course.
Anything under 50ms is considered acceptable.  People obsess about ping far too much.  Human reaction times are about a 1/12 of a second or 85ms, so you’re not going to see the difference between 30 & 5.  I’d be more concerned if it was varying a lot.
Anonymous
Not applicable
Message 3 of 3
@Daniel92
"Running a speed test they get 5ms but when I run a speed test on my network I get 30ms."
How exactly are you both running these speed tests?
Are you both using wired ethernet devices, (not WiFi), of a similar specification, using the same speed test website and if selectable, the same distant server, and at a similar time of day?
***EDIT***
@WSHwrote:
"Anything under 50ms is considered acceptable. People obsess about ping far too much. Human reaction times are about a 1/12 of a second or 85ms, so you’re not going to see the difference between 30 & 5."
I have recently moved to Zen Internet FTTP via CityFibre. For historical reasons I have for many years kept a spreadsheet of my broadband's performance. I still do a daily speedtest on Ookla to Zen's London server. My download latency always measure somewhere between 100 and 200miliseconds! As we are not gamers, we don't notice it.
