Message 1 of 3
3rd Party Router/Firewall and IPV6 on FTTP
Hello,
I would like some advice on how I can set up IPV6 on BT FTTP.
Router/Firewall: Sophos XG 20.0.2 MR-2
The WAN interface of the firewall is directly connected to the ONT. It has been running fine this way for the past 2 years using PPPoE and the usual configuration for a 3rd party router/firewall for IPV4.
I went to enable IPV6 configuration today following pieces of information I found for PFSense/OPNSense but I am unable to obtain a IPV6 assignment. Screenshot of the current configuration is below.
Has anyone had any luck in getting IPV6 working using Sophos XG? If yes, would you be able to share a comparative screenshot of your configuration?
2 REPLIES 2
Message 2 of 3
Re: 3rd Party Router/Firewall and IPV6 on FTTP
Select delegated. BT implementation is /56 PD
Message 3 of 3
Hi licquorice
I thought that might be the case but the screenshot below shows a few interesting things.
Upstream Interface* - None present on the dropdown. I am editing the WAN interface here.
IPv6 Address - I am only ably to enter data in the Subnet ID and Interface ID fields.
Router Advertisement - Off by default. Turned On.
DHCP v6 Server - Off by default. Turned On.
Gateway Name* - Blank by default. Defined in the same fashion as the IPV4 Gateway Name.
Gateway IP* - Blank by default. Not sure on what to enter here.
The fields marked with a * are mandatory. Leaving everything as is in the screenshot, I cannot save the configuration as I am expected to input a Gateway IP.
