Message 1 of 2
3rd Party Router with Complete Wifi
Hello,
I have FTTP + Complete Wifi. I also have an ASUS DSL-AX82U which works with Full Fibre. I am aware you are unable to use complete wifi discs with 3rd party routers. However -would it be possible to set up my SH2 as an access point for my ASUS router and have the wifi disc connect to the SH2 instead of directly to the 3rd party router?
If this is possible, I'd have faster speeds from my 3rd party router whilst maintaining complete wifi (black discs).
Any help is appreciated. Thanks!
1 REPLY 1
Message 2 of 2
Re: 3rd Party Router with Complete Wifi
I can't see any reason why it wouldn't work. The BT hub doesn't need a DSL input for WiFi to function. Try it and see.
