Message 1 of 5
ASUS DSL-AC88U AC3100 Modem/router setup
I'm looking to get a 3rd party modem router combo and replace our bt hub I was wondering if the ASUS DSL-AC88U AC3100 Wi-Fi Gigabit Modem Router would be compatible with our bt package and how i would go about setting it up. I've attached a picture of the master socket below and the package we have is fibre with bt halo 2. Thanks in advance
4 REPLIES 4
Message 2 of 5
Re: ASUS DSL-AC88U AC3100 Modem/router setup
@jasonh99
Yes you could use that device.
Setup VDSL, assuming it not a full fibre connection.
PPPoE
username of [email protected]
Password BT
Message 3 of 5
I dont have it yet but where do i go to enter that just the 192 address and then set it up in the master socket/ pc with ethernet the same way the hub is currently
Message 5 of 5
alright thanks.
