Message 1 of 4
Home hub set up
My old laptop runs WindowsXP.
Can I connect wirelessly to my new hub or do I need to use Ethernet connection?
3 REPLIES 3
Message 2 of 4
Re: Home hub set up
The home hub hasn't got a clue about what operating system you are using. As long as your wifi card/dongle is 802.11  b/g/or n it will work. You might need to select wireless mode3 in advanced wireless settings though.
Just try it.
Message 3 of 4
Re: Home hub set up
Thanks for your response
My Wi-Fi card conforms with 802.11b/g/n
Wireless mode doesn’t give me the option to select WM3
Any further hints?
Message 4 of 4
Re: Home hub set up
If you go to hub  manager then advanced settings then wireless you should be able to change wireless mode if necessary
