Message 1 of 3
Advise I need a Wifi Extender as my security outside camera has a very weak signal ?
2 REPLIES 2
Message 2 of 3
Re: Advise I need a Wifi Extender as my security outside camera has a very weak signal ?
This is a customer to customer forum - you're not talking to BT. You need to call customer services to ask for a WiFi extender.
Alternatively, consider buying a WiFi mesh system. They're not that expensive and will avoid the monthly extra charge BT may make if they supply you with extenders.
Message 3 of 3
Also worth considering where your router is currently positioned. Could it be moved to a more central/appropriate location with a longer cable for example?
