Message 1 of 5
BT whole Home Wifi Disc Roaming issues
Hi,
i have 6 original whole home wifi discs (white ones) - i have EE broadband fibre connection with wifi 7 router supplied by EE but i have disabled wifi on the EE router so that i only use my mesh.
i have one disc connected directly to EE router via cat6 and then from a different port on EE router i have a non-managed Mercusys 8 port poe switch which serves connection to my other 5 discs in the house and Garage.
the network works fine but i face a lot of issues when my laptop or iphone roams from one disc to another - it seamlessly gets internet access but losses access to all the devices connected to the disc it roamed away from, it takes 5 mins for that device to be accessible.
i tried to resolve arp when the issue happens and my laptop cannot even get a response for the arp request so it points to an issue only when i roam from one disc to another.
i understand whole home original white discs do support the Ethernet backhaul connectivity i have in my home but it seems steering is getting delayed by 5 mins. I have disabled legacy steering and enabled compatibility mode but no luck.
i am on latest firmware for the discs which is build 14- please advise
4 REPLIES 4
Message 2 of 5
Re: BT whole Home Wifi Disc Roaming issues
Hi @gauravgangwani,
Welcome to the Community!
It may be worth reaching out to our team, so they can take a look into what is going on.
Rach
Message 3 of 5
Hi, how do i reach the support team ?
Message 4 of 5
That nice Mr Google says  0808 100 6116
Message 5 of 5
Hi @gauravgangwani
You can find all of our contact information on our contact us page. Hopefully, our support team can help find a solution for you.
Chris
