Message 1 of 6
Allocating dedicated channels
I have a number of devices for smart home that lose connection to my WiFi periodically.  I’m told by the provider that I need to allocate a separate channel on  2.4Mhz that only has these devices on it.  Apparently by not having the smart home devices on the same channel as other devices eg iPads etc, will stop the connection dropping off that I  suffer from.
will this work and ,if so, how do I do it please ?
many thanks
5 REPLIES 5
Message 2 of 6
Re: Allocating dedicated channels
It's total nonsense and can't be done in any case.
Anonymous
Not applicable
Message 3 of 6
@Steve997
You could set up a different wireless network for those devices - but only if you buy a separate wireless access point, fix its 2.4GHz "broadcast" channel, (eg ch 6), and then fix the 2.4GHz channel on your Hub to something else, (eg 1 or 11).
Having said that it, as @licquorice has already said, it is almost certainly pointless.
Message 4 of 6
Thanks for responding.  Sounds like no more time to be spent on this.
Message 5 of 6
Thanks for responding.  As I said to the other reply, sounds like no more time to be spent on this, I’ll need to ask them for another solution
Message 6 of 6
If it's not too much of a pry, what are the devices in question?
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
