Message 1 of 2
Allowing access to my home network
I have equipment at home that i need to connect to a specific server in the outside world. I have set this before on an older Home Hub by adding a device into Port Forwarding but the option to specify the Server address does not seem to be there now. Short of disabling my firewall, I am not sure how to continue. Thanks
1 REPLY 1
Message 2 of 2
Re: Allowing access to my home network
If you are connecting to a server outside of your network you don't need port forwarding. Port forwarding is used for external sites connecting to a server on your internal network.
