Message 1 of 4
Alternative Router
Can anyone recommend an alternative  router for the smarthub 2. I have FTTP & would like to be able to split the wifi signals. I don't use landline. TIA
3 REPLIES 3
Message 2 of 4
Re: Alternative Router
That's like asking for recommendations for a car. Only you know what whistles and bells you want and what your budget is. Any PPPoE capable router with a WAN port (which will be virtually all)  will suffice.
Anonymous
Not applicable
Message 3 of 4
If splitting the SSIDs is the only requirement then an FTTP variant of the original Smart Hub would do the job for little cost from Ebay or Facebook Marketplace.
https://www.bt.com/content/dam/bt/help/legacy/4043%20BT%20Smart%20Hub-A%20SI%20FTTP%20User%20Guide%2...
But you need to ensure that the 4th ethernet port is a red WAN port as unlike the SH2, I don't think the standard versions can be reconfigured.
Message 4 of 4
I would keep the Smarthub 2, turn off wireless and add a wireless point. Either a something like an Ubiquity or a repurposed router (turn dchp off) that had decent wireless performance.
