Message 1 of 3
Any way to split the 2.4 and 5G networks with separate names?
Can't find anything on the hub that allows me to change the 5G name.
2 REPLIES 2
Message 2 of 3
Re: Any way to split the 2.4 and 5G networks with separate names?
if you have the SH2 then you cannot split the 2.4/5ghz networks - both have same SSID
Message 3 of 3
That's a pity but thanks for the quick answer
