Message 1 of 3
Asus DSL-AX86u on superfast ONT
Just got my superfast 900mb installed today. Had been using the Asus DSL-AX86u on Plusnet ADSL previously straight from the phone line. Tried setting up to replaces the hub 2 with the Asus. Ran the red ethernet cable from the little wall ONT to the WAN port on the Asus similar to the hub 2 setup and entered the WAN DSL settings and inputted the username and password as listed into the forums. Still not detecting the connection, tried a few settings but was looking for a guide from start to finish to ensure I'm doing it correctly.
Tags (3)
2 REPLIES 2
Message 2 of 3
Re: Asus DSL-AX86u on superfast ONT
This is what mine looks like on the AX88, have you power cycled the router since changing over to FTTP?
Message 3 of 3
Thank you, you're a legend. Settings helped. Turns out it was the Dual Wan tab in the same section. Had to set it on and switch WAN to primary connection and DSL to secondary after a few minutes it detected the connection and worked.
