Message 1 of 24
Auto EE wireless connection?
I was switched to EE. No new hub. Now I can't automatically connect via wireless. Can someone explain in words of one syllable or less whether I can ever go back to the days of setting the username and password to be entered automatically on connection instead of having to manually pull up the web page, click on EE, click on log in and type everything in, every single time?
23 REPLIES 23
Message 2 of 24
Re: Auto EE wireless connection?
Are you talking about your home WiFi, or the ability to connect to public hotspots when out and about?
It sounds like you're trying to connect to the 'EE WiFi' network which is not your home WiFi, it's a public hotspot service that anybody can use which your EE/BT hub contributes to. Connecting to this network will always take you to a 'walled garden' page that will expect you to authenticate with your BT/EE account details.
If you are trying to connect to the WiFi of your existing BT hub now that you've been moved across to EE, then you should be using the same WiFi network name you always have, typically something like 'BT-A12BC3'.
Message 3 of 24
Home wireless, the old BT wireless login no longer works. I either need a wired connection or to go through a web page to connect.
Message 4 of 24
That makes no sense whatsoever, it is your router that determines your WiFi login not broadband provider. If your hub hasn't changed, your WiFi login hasn't changed.
Message 5 of 24
had you changed the SSID and wifi password on back of hub to something you prefer?  if so was there a factory reset when you moved to EE as that would cause hub to revert to original SSID and password shown on back of hub and not your changed version
if that is case you need to go into hub manager and change SSID and password back to your preferred version
Message 6 of 24
No, I'd made no changes. Still using all the details as provided with the hub.
Message 7 of 24
@Quidnunc
if you made no changes to SSID or wifi password then as @licquorice posted it makes no sense that your devices will not connect to the existing wifi with your existing password
I would go to hub manager and then wireless and check what SSID and wireless password are shown and then you will be able to either change to what you want or just connect devices to what is shown
Message 8 of 24
What device and what operating system is it that you are using that will not connect?
You have said that you are using a web page to connect. Why?
That would normally only be necessary if you are trying to connect to EEWifi  and not your own home's wireless network which will still be as per the details shown on the label on the BT hub..
See link for how to connect to your BT hub if that is still what you are using.
Connect your devices | BT Help
Message 9 of 24
When you were changed from BT to EE, did they provide you with a new hub? If so, you need to use the WiFi login username and password that came with the new hub, not the one that the old BT hub used.
AFAIK, there is no way you can login to your hub-provided WiFi by going to a web page on, presumably, an ethernet cable connected computer, so I don't understand what exactly you are doing.
Message 10 of 24
I guess you missed the part where the OP said no new hub was provided.
Along with you and others, I too am mystified why the OP is using a web browser to log into WiFi.
