Message 21 of 24
Re: Auto EE wireless connection?
None of this is necessary, the hub hasn't changed!!!
The change of ISP is irrelevant.
Message 22 of 24
I know, but if the OP has been messing around with their WiFi connections then there’s a chance they have made changes that has messed something up. This at least removes those changes and starts again from scratch.
Message 23 of 24
As has already been pointed out multiple times there should have been no need to change anything. The phone is none the wiser which ISP, EE or BT is supplying the connection and neither is the BT hub. The phone should have connect to the BT hub by its self when the broadband started.
The phone would not have selected the EEWifi signal which caused the EEWifi logon web page to open, that would have required human intervention to have made the connection and then enter the details.
I suspect that for what ever reason the the OP is not following everything that has already been suggested and that there is user error when trying to connect and as such I will now bow out of this thread.
Message 24 of 24
The only thing that seems to fit @Quidnunc's description is that instead of connecting to their router's SSID, they've always been connecting to the WiFi Hotspot, using the old BT WiFi app. In which case following @tonysmini018's advice should get them online.
