Message 1 of 20
BG smart wall socket
Hi i have purchase a BG smart wall socket .but i am unable to get it to connect to my BT route ? I have spoke to the makes of the socket and they gave me so tips
one was told to use 2 mobile phones and to make a hot spot and connect the other phone to in and program the socket and that will connect so they say that the socket is working fine
i have been in to the route setting and turned it to 2,4 and set the fire wall to off but it still will not connect
they say i need to find the white/black noise and enable the device but i cant find that settings in the router
any help would be appreciated
i have a BT hub at work and that is doing the same as the one at home
19 REPLIES 19
Message 2 of 20
Re: BG smart wall socket
Turn the firewall back on, that will have no effect on your problem but will be a security risk with it turned off.
Not surprised, no idea what they meant by that.
Try turning off smart setup on the hub https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
Temporarily turn off the 5Ghz wireless until the smart socket is connected and then turn it back on again.
Message 3 of 20
Youn have the BG app downloaded and you have a BG account set up?
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 4 of 20
I setup 2 of these at the weekend and had a couple of issues setting them up but managed to do it by doing the following.
Log into the hub and turn off the 5 ghz network, smart setup was already switched off.
Start the setup of the socket using the app on the phone, I did this using my iPhone, the lights on the socket flash red and the setup failed.
After the failure the app prompted me to setup the socket using the AP config, follow the prompts on the app about pressing the buttons on the socket then about switching off mobile data on your phone and then how to connect the phone to the socket and then connecting it to your hub.
All in all it was a bit of an effort connecting it to the BT hub, I have one in the garage that was setup with an external Wi-Fi extender and that connect first time without needing the AP setup, so perhaps they just have issues with the not so smart Smarthub?
The only option you don’t get using the AP config is to set any additional sockets as sub devices so they get configured as master units rather than a mesh setup.
Enjoy?
Message 5 of 20
Thanks for the replies
I have the app on a iPhone and android both fail to connect
I have the router set too 2.4 ghz and the fire wall switch off
I have tried up both ways with lights flashing fast and also in Ap mode both fail on last page saying it can't find the BG app
Message 6 of 20
As was previously mentioned you don’t need to switch off the firewall you just need to switch off the 5ghz network on the Smarthub.
It might also be worth switching the Wi-Fi off on the iPhone and then back on again to make sure that it’s connected to the 2.4ghz network before you start the setup.
Did you also get to the point in the AP mode setup where the app prompts you to turn off the cellular data on your phone?
It might be worth switching this off as well before you try setting the switch up in AP mode.
Message 7 of 20
Hi thanks
I switch of 5 ghz and only have 2.4 ghz on
I switch off mobile data then I start the programming on Ap mode
This is what I get on the last page of programming
Message 8 of 20
As part of the setup you need to connect you phones Wi-Fi to the AP Wi-Fi that the socket is broadcasting have you checked to see if it’s listed under Wi-Fi devices and can you connect to it?
Message 9 of 20
Here is what i have done
i have made up an extension lead with the BG socket at the end
i took the lead to work where we have the latest BT smart hub
i phoned BG tech department and with the socket plug in we tried to set it up together but failed every time
he think that they must be a setting in the router that is causing the issue
so  i deleted the app and re-installed again
went back in to the home router and switched off the set up wizard and tuned off 5mhz then rebooked the router
tried again and failed  )app is searching for device ap named bg home
This is the check list they sent me
Cannot set up device
1.
Please LED status:
Flashing rapidly- go to 2
Flashing slowly- go to 3
Turn off- go to 4
Flashing slowly intermittently- go to 5
2.
Please follow below steps to do trouble shooting:
1) make sure smart phone is connected with 2.4 GHz.
2) take smart phone, device and router close to each other
then try again to set up device
3) router’s Wi-Fi setting is b/g or bg mode
4) long press reset button for 4-5 seconds until LED flashing
4 times intermittently, which means device is in AP
mode then set up device
5) Ensure that no VPN is active on the smart phone/Handset
or the router.
3.
1) No special characters or non-English characters are
included in the router SSID or password. We
recommend to use English characters and numeric , and
length should not exceed 32.
2) Disable blacklist, whitelist, MAC address binding, etc. in
router Wi-Fi settings. It is recommended to add
device MAC first then enable these settings but this may
cause device offline;
3) The distance between the router and the device should
not be too far.;
4) Make sure the router's 2.4G WiFi signal is on
5) Make sure the router has DHCP service enabled
6) If the router is connected to more than 30 devices, please
disconnect some devices then set up device
7) Following the instructions in App, reset the device to AP
mode (long press reset button for 4-5 seconds until
LED flashing 4 times intermittently) then set up device
😎 If the above methods still do not solve the problem, then
please try mobile phone hotspot as following:
a) Prepare two phones ;
b) Turn on "mobile hotspot" in the phone A, and set the
WiFi name and password
c) Connect phone B to the hotspot of phone A;
d) Open App and click on add device to see if it can be set
up;
e) If set up is successfully by above steps, but failed when
mobile phone is connected with router,
then try to restore the router to factory settings;
f) If tried steps a) to d) but still failed, then the equipment
may be faulty. It is recommended to contact the
seller to return this device.
Ps i have already exchange the socket
Message 10 of 20
Okay - but when in AP mode are you connecting your phone by wifi to the SSID being broadcast by the smart socket NOT the SSIS of your router?
