Message 1 of 2
BROADBAND & WI FI
Hi,  Earlier this year, I had conversion from copper to Wi Fi.
Installation was carried out by Openreach, who placed the router near a window & radiator and behind the TV, all of which is against advice on BT website.
In order to use the PC in my preferred room (where the previous router was installed)  I used a pair of extender flex 600 in order to enable the PC to operate reasonably well.
However, some has pointed out the 600 kit would be unsuitable for the 150 Gig? speed provided by the package.   Speeds "to the property" have been checked and confirmed as 150.
Was suggested the PC may not be suited, but upon checking, it is capable of handling the higher speed.
Please can anyone suggest  a suitable extender kit.
1 REPLY 1
Message 2 of 2
Re: BROADBAND & WI FI
https://www.tp-link.com/uk/home-networking/powerline/tl-wpa8631p-kit/
However, any powerline adapter will only be as good as your electrical wiring.
