Message 1 of 3
BT Digital Voice Adapter and BT Mini Wi-Fi Hotspot
Apologies if question has been raised already.  Preparing for FTTP install.  We will need to retain  our Wi-Fi Hotspot, but also will need BT DVA.  Are these compatible - plugged into same circuit?
2 REPLIES 2
Message 2 of 3
Re: BT Digital Voice Adapter and BT Mini Wi-Fi Hotspot
The DVA doesn't utilise the mains wiring. It is just mains powered device to transform an analogue phone into a DECT handset.
Message 3 of 3
Many thanks, problem solved.
