Message 1 of 8
BT Extender wi-fi discs
I have 4   BT wi-fi extender discs (the black ones).  Which are connected to my Smarthub 2.
Does anyone know how to find the IP address for each of these discs?
7 REPLIES 7
Message 2 of 8
Re: BT Extender wi-fi discs
You may find them in the details on your hub at http://192.168.1.254/basic_-_my_devices.htm
Message 3 of 8
Thank you.  Would these wi-fi discs not show in the "my bt" app under "your wi-fi network" and then "control wi-fi access for your devices"?
There are many "unknown devices showing"
Message 4 of 8
Yes. They show up in myBT. I've named them so I know which is which. I chose Broadband and then "set up and manage devices".
Message 5 of 8
Do u find your wifi speeds directly from your hub slower, with discs connected?
With my discs off i can recieve 400mb to my phone, over wifi. With 3 discs turned on, im lucky to recieve 200mb to my phone, when connected directly to the hub wifi
Message 6 of 8
Hi there
What do you mean  you chose Broadband and then "set up and manage devices"?
Message 7 of 8
No. I've noticed no difference.
Message 8 of 8
"What do you mean you chose Broadband and then "set up and manage devices"?"
I used the BT app. Chose "Your products" then broadband then "setup and manage devices" That showed me the hub and associated discs
