Message 1 of 3
BT Hub 2 USB data sharing problem
hello everyone
i try data sharing from hub with 1TB external ssd, i connected to myssd but when i started upload ,it stop at est. 6.5 gb.
i couldnt understand problem
also i tried move some documents(10gb)  into myssd direct from laptop usb , and when check from wifi after plug in hub usb , i couldnt see anything .
if upload from network , other users can see those on network.
i hope i explain myself../
Thank you
2 REPLIES 2
Message 2 of 3
BT HUB Interface user adding problem
Hello again,
I want to add/edit/assign authorization to users for hub usb external ssd,but I couldn't see the add or edit user section in the hub interface.
example. 2 user, one is ReadOnly other is  ReadWrite.
Thank you
Message 3 of 3
Re: BT HUB Interface user adding problem
There is no facility in the hub manager to add/edit or assign users. It is just a USB interface accessible by any user accessing the hub, any permissions are related to the operating system of the device accessing the drive or the drive itself.
