Message 1 of 6
Wi-Fi network not showing up
Our home Wi-Fi has gone down for the last 2 days.
It is not showing on our network list on any device.
I have tried factory reset button, unplugged, turned off/on.
Router has a solid blue light.
Any suggestions on solutions very welcome!
5 REPLIES 5
Message 2 of 6
Re: Wi-Fi network not showing up
What model router is it?
Message 3 of 6
Smart Hub
Message 4 of 6
I would check to make sure that the WiFi has not been disabled in the SH, but since you say you have tried a factory reset that wold seem unlikely. Simplest option imho will be to call BT CS and report it as a faulty hub, they may replace it with a SH2 though.
Message 5 of 6
Sorry for my lack of knowledge but what is SH?
Message 6 of 6
Smart hub
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
