Message 51 of 87
Re: BT Hub M
It doesn’t work.
Message 52 of 87
Re: BT Hub M
It does.
What error are you getting?
Are you sure you are entering HTTPS://192.168.1.254
Message 53 of 87
Re: BT Hub M
Secure Connection Required
Access to the Hub Manager now requires a secure
HTTPS connection.
SWITCH TO HTTPS
• You might see a browser certificate warning - what do I do?
16:10 Sat 3 Jan
192.168.1.254
This Connection Is Not Private
This website may be impersonating "192.168.1.254" to steal your personal or financial information. You should go back to the previous page.
Show Details
Go Back
Message 54 of 87
Re: BT Hub M
Yes, just accept it.
Message 55 of 87
Re: BT Hub M
Accept what there is nothing there to accept I have been through all the options BT tech support offered they do not accept there is a change in the Hub protocol/ firmware that would cause the rejection of my link and finally as I said earlier suggested it was an Apple problem despite the fact I had been using this I pad  perfectly well until a week or two ago. They hard reset the hub refreshed the hub I switched the I pad off and on. Have had enough now no solution.
Message 56 of 87
Re: BT Hub M
Click on the link I posted and when your browser complains about the certificate just accept the warning and continue.
Message 57 of 87
Re: BT Hub M
@George49
If there is a box "Advanced" click on that then click on continue to BT homehub or click on "Show Details"
Message 58 of 87
Re: BT Hub M
Going to stop for now thanks for all the comments I will let the community know if anything works.
Message 59 of 87
Re: BT Hub M
If it's an Apple device, I take it you're using Safari as your browser?  In which case, it's click on "Show Details" and then click "Visit this website".  You'll need to confirm by clicking "Visit Website".
This is just Safari being over cautious and warning you that, because the connection is not encrypted, it is just possible that someone may be listening in or impersonating the website.  Of course, as you're connecting to your own router inside your own network you know it's not fake and so it is safe to ignore the warning and proceed.
Message 60 of 87
Re: BT Hub M
Yes it is Safari and yes I am not concerned other than not being able to access the hub, there are numerous devices in my house and being able to monitor performance without contacting BT was easy now impossible.
