Message 41 of 87
Re: BT Hub Manager - recent changes
They were, but I've changed back to WPA2 and everything is now working ok.
Message 42 of 87
There is no mention of any update or WPA3 on the business forum which if there was an update that defaulted to WPA3 only I would have expected at least one post regarding it.
I do not have a Smarthub3 so can not check to see the firmware or the options regarding WPA3 or if it has recently been added or has always been an option.
If it has always been there could it have been changed to WPA3 by someone in your house hold i.e trying to get around access controls or parental controls?
Message 43 of 87
In response to your query about someone changing to WPA3, the only other person in our household is my Wife, and no disrespect to her, she wouldn't have a clue.
I don't really look at the Hub manager very often, but noticed the other day that my android phone and iPad would not connect to my BTWholeHome mesh system whilst down stairs, so had a look and that's when I noticed the WPA3, so I guess it's quite a recent addition. I've changed the default back to WPA2 and they are now working ok, so I am only guessing that WPA3 is the culprit. Again I stress that I am no tech genius and I maybe totally wrong.
Message 44 of 87
I'd expect a lot of posts! No way BT would have intentionally forced a change from WPA2 > WPA3-Personal. To do so would be madness. A hefty chunk of devices in customers' homes don't carry support for strict WPA3. Case in point: of > 40 devices on my network, roughly half support WPA3.
@PeteK222 - suggest just changing the option back to either WPA3-Personal-Transition or WPA2-Personal and  calling it a day. Keep an eye on things to see if it happens again the next time there's a firmware update.
On the HTTPS debate...
... there is no explanation of why this move to https is needed.
I noticed recently that AsusWRT have  done similar with their firmware. Makes me suspect it's the result of some regulation or other.
Message 45 of 87
More likely to simply reduce help desk calls due to browser's barfing.
Message 46 of 87
I'd agree were it not for the fact that a browser will barf more when presented with a self-signed cert versus plain HTTP 😉
Message 47 of 87
Re: BT Hub Manager
I have just been advised that the problem accessing my home hub manager page is because I am using an Apple device, in this case an I pad. That is despite the fact I have the same problem on my Samsung mobile phone.
Message 48 of 87
Re: BT Hub Manager
You couldn't make it up.
Message 49 of 87
Re: BT Hub M
I couldn’t BT apparently can. Seriously there appears to be no solution I have spent 45 minutes in chatt room with BT helper then a 20 minute phone call arriving at the description I originally posted.
Message 50 of 87
Re: BT Hub M
The solution has been posted, use HTTPS and accept the self signed certificate.
