Message 71 of 87
Re: BT Hub Manager - recent changes
checking again it looked like I had two passwords stored in firefox and it was picking up an old one when logging in under https.
Message 72 of 87
window11 network desktop app no longer connects to hub 2.0 manger since i have changed hub any ideas on settigns
Message 73 of 87
network desktop app on windows 11used to connect to my hub manger
 had can anybody advise why my desktop network app on window11 does not connect to my hub manger 2.0 it did used to   but since have change hub as warning  had warning message of security alert message which still is the case but been informed to ignore message
Message 74 of 87
Re: network desktop app on windows 11used to connect to my hub manger
yes just ignore the warning about HTTPS and proceed anyway and you will get to hub manager - not a problem
Message 75 of 87
I have the same issue and have followed the advice here, but neither on my phone nor my Mac on safari, will it allow me to actually login. It just hangs indefinitely. I really need to login to my hub urgently.nAny ideas anyone please?
Message 76 of 87
try a different browser  you phone may need to be in desktop view
Message 77 of 87
No doubt due to Apple's paranoia regarding certificates. The problem lies with your devices, not BT. You need to override any security warnings.
Message 78 of 87
Hi there. I did override the warnings as instructed on here but the page just hung. I eventually decided to try on Chrome browser and it was fine once I’d ignored the warnings . It’s obviously something else that doesn’t work on Safari (just like my cctv 🙄)
Message 79 of 87
I recently received a Smart Hub 3, unable to connect an old printer that runs WPA PSK, switched on compatibility domain. No luck tried several times… given up, HUB being returned, will stick with Smart Hub 2 at least until printer expires.
Message 80 of 87
Did you also change the security type from the default WPA2-Personal to WPA-WPA2 Personal in  the Comp WiFi settings?
