Message 61 of 87
Re: BT Hub M
Have you read my first paragraph?
Message 62 of 87
Re: BT Hub M
Message 63 of 87
Re: BT Hub M
Thanks for all advice, just sorted.
Message 64 of 87
Re: BT Hub Manager - recent changes
This FULLY the responsibility of BT! They have made a change without testing against the most common browsers.
I think that Chromebook works as it is not particularly good at security, whereas Edge, Firefox do!
Come on BT, get it working!!
Message 65 of 87
Both Edge and Firefox work if you set them up properly.
Message 66 of 87
Give us a clue...
Message 67 of 87
@CommunityFezwrote:
Give us a clue...
Read message 18
Message 68 of 87
I had changed my admin password and it looks like they also reset this to originally supplied one on the back of the router.
Message 69 of 87
Strange.  It didn't reset mine.
Message 70 of 87
My one was also not reset.
@mike63uk
If you have children and parental controls are you sure that the children did not do a factory reset on the hub so as to overcome the parental controls as this would mean that any passwords would be reset to the factory default.
