Message 1 of 2
BT Hub with 3rd party router
Hi,
It's looking likely that I'll be offered FTTP soon in my area (according to Openreach) so I'm trying to get ahead of the game as such and do my research up front so I know what I might be up against.
I currently have an Huawei HG612 on FTTC which is being run into a Ubiquiti UDM-Pro, couple of Unifi switches, cameras and AP's for WiFi.
Needless to say I wouldn't want to stop using any of this hardware and I understand that to use Digital Voice I need to use the BT Hub.
What would be my best way of configuring the hub to work with the UDM-Pro? I understand that I'll be double natting, etc. but I'd rather not source another provider for VoIP and the family want to still have a landline so I'm kind of stuck with it.
Thanks.
1 REPLY 1
Message 2 of 2
Re: BT Hub with 3rd party router
Just connect the hub as the first device, turn off DHCP and WiFi. Give the UDM WAN  port a static IP address of 192.168.1.10 and gateway 192.168.1.254 and connect it to a Hub LAN port.
