Message 1 of 5
BT Premium Whole Home WiFI with a 3rd Party Router
Hi
I have changed to another broadband provider with a different router. I've connected my BT Premium Whole Home (White) WiFi discs and they are working as normal.
However I cannot get the BT Whole Home app to recognise them any more.
Is this expected behaviour since I am no longer using BT broadband?
Thanks in advance.
4 REPLIES 4
Message 2 of 5
Re: BT Premium Whole Home WiFI with a 3rd Party Router
No, the white discs are specifically intended for non BT customers.
I suspect your new router uses a different IP subnet and the app is trying to connect to the old address.
Try stopping and restarting the app.
Message 3 of 5
Thank you.
I have deleted the app and reinstalled it but it still does not work.
Message 4 of 5
Try giving the whw help desk a call
 0808 100 6116
Message 5 of 5
This has now been resolved via Firmware updates.
Thanks again for the advice and telephone number.
