Message 1 of 5
Hub Manager report
Can anyone please explain what Hybrid Status - no connection actually means?
4 REPLIES 4
Message 2 of 5
Re: Hub Manager report
Do you have a hybrid connect device?
I suspect not, hence report.
If you do have one, it is not connected.
Message 3 of 5
What is a hybrid connect device?
Message 4 of 5
An additional device that plugs into the hub and provides a backup connection using the mobile phone network should the main broadband connection fail.  An expensive add-on and only necessary if you live in an area with unstable landline connectivity.
Message 5 of 5
If you need to ask you obviously haven't got one. Hence you can ignore the report.
