Message 21 of 23
Re: BT Premium Whole Home vs Toob
Hi
did you manage to find a wifi extender/booster system for your toob in the end as I’m looking at to find something that works with toob.
Message 22 of 23
I went for a Netgear Orbis router and mesh system to replace both the Toob router and the BT mesh system. Works brilliantly but is pricey!
Message 23 of 23
Did you try any other mesh systems with the toob router before going with the netgear system?  Did you go for the neat gear 6 or 6E system?
