Message 11 of 23
Re: BT Premium Whole Home vs Toob
If I turn wifi off on the hub how will I connect to it?
Message 12 of 23
The first disc needs to be connected via Ethernet. The discs are intended to be used as a standalone mesh with wifi disabled on the prime router.
You can obviously still also connect to the Toob router with Ethernet to your laptop.
Message 13 of 23
Ok I’ll give that a go
Message 14 of 23
Factory reset the discs before trying to connect as the Virgin and Toob IP subnets are probably different.
Message 15 of 23
Yeah I am just in the process of doing this
Message 16 of 23
Done this followed the app guide and when I try to connect to the main disc, it connects then unable to detect disc.
discs have been factory reset, disc is connected via Ethernet and is connected to mains, wifi is off on the main TOOB router.
I don’t know what else to try as all this equipment works from my current virgin router!!
Message 17 of 23
Nor do I, I'm afraid. The problem clearly lies with the Toob router however as the discs work ok with Virgin and other providers.
Can you borrow a third party router to see if that works ok with Toob broadband (perhaps from Amazon 😉)
Message 18 of 23
My phone shows me connected to the BT discs for a few seconds then it disconnects when I’m in the app trying to connect to the first disc??
Message 19 of 23
I can connect to the wifi signal, but won’t connect to the disc, and the wifi signal drops when trying to connect to the disc. So strange
Message 20 of 23
I’m connect right now and using the wifi from the disc to sent this message but as soon as I go in the app to connect to the disc it kicks me off
