Message 1 of 3
BT SH3 & UPNP Setting
Folks
On setting the router up i notice UPNP is switched on, I have no clue what this does !!
Will it affect my connected devices if I turn it off??  Cameras, bulbs, Alexa etc!!
2 REPLIES 2
Message 2 of 3
Re: BT SH3 & UPNP Setting
@Jasonuk1975  For most home users, you should keep Universal Plug and Play disabled on your router because it creates a security risk by letting local devices open network ports without your approval.
I personally never have UPnP enabled and I use my own router. I don't even have WPS (WiFi Protected Setup) enabled on my router.
I have over 30 WiFi devices connected simultaneously and not having UPnP enabled doesn't affect anything at all. That includes light bulbs, security cameras, washing machine, dishwasher, the works.
Message 3 of 3
UpNP has been switched on by default on all BT hubs. Switching it off will have no effect unless you are a gamer or expect unsolicited incoming connections to your devices. Unless required, it is always more secure to disable UpNP.
